Install to eMMC using ceemmc
Hi there,
I’ve just installed android to eMMC to my KHADAS VIM3 and tried to install CoreELEC-Amlogic-ng.arm-20.0-Nexus to eMMC for dual. eMMC boot.
When SSH to CoreELEC i have the following…, could You help me out what am I doing wrong?
CoreELECvim3:~ # ceemmc
Starting CoreELEC eMMC installation tool...
eMMC size: 0x000747c00000 [32GB]
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
  Use CoreELEC data from
Install in single boot mode, only CoreELEC on eMMC
    [3] current used SD or USB device
    [4] existing backup on current used SD or USB device
Please choose one option? [1/2/3/4]: 1
Free space of 'partition CE_FLASH': 512MB
Free space of 'partition CE_STORAGE': 24126MB
Used space of '/flash': 242MB
Used space of '/storage': 7MB
There is enough free space on eMMC for installation!
Install CoreELEC on eMMC.
Continue? [y]: y
Error dtb magic: !
Could not remove node '/partitions' from dtb0!
Failed to write the new partition table to eMMC!
Try another Android firmware version.
I did install with USB burning tool three different images. CEeMMC tool was working on all instances. Then tried again writing the latest image with owow and I had the same error as previously with ceeMMC.
Conclusion. vim3-android-9-64bit-v230130.raw.img.xz is corrupted in some aspects or owow is missing something.
So thank you. CEeMMC is working when updating VIM3 with USB Burning Tool.
