Hi
I bought a “Beelink GT-King Pro”.
With the device, there was a SD card containing CoreELEC.
But whatever I tried, I could not enter to CoreELEC.
I formatted the SD card, then I downloaded the new CoreElec version and installed it on the SD card using the Rufus software. But after the installation, the SD card will not be seen between other PC drives !!
Again with the Rufus software, I formatted the SD card (after formatting, the SD card is seen between drives) and re-completed the previous steps, but did not have a result.
No need to format the SD, just install the .tar,gz using Rufus.
Eject the SD and put it back to the PC, copy the dtb and thats it.
If You don´t want to use Rufus, try Etcher
I copied the “g12b_a311d_beelink_gt_king.dtb” file and changed its name to “dtb.img”.
(I didn’t find a file called “g12b_a311d_beelink_gt_king_pro.dtb”)
This worked and CoreELEC was run.
Thanks Tim
Should use putty and install to internal/ emmc now for a much more stable CE with dual boot, been running this box this way for a few yrs now with great results.
(Off the top of my head) in putty type in your ip address, username is root, password is coreelec. Then type ceemmc -x and hit enter, choose the option to copy contents from sd card in dual boot mode.
