Hello everyone,
I’ve been coming to the Forum for a few weeks now because I was waiting to receive my Odroid N2, which is the case today.
I ask myself lots of questions to use CoreElec correctly. First I think to install CE on sd card, I will see later to use eMMC, I have browsed the web a lot and found some good info (especially in this forum). I recently saw that it was necessary (after having burned img. On sd card) to open device_trees and to copy the n2 file then to rename it dvb.img and do not forget to delete the previous dtb disk image file. Is that correct to boot CE on N2 and then be able to set everything that I need in the settings? If already at this point I am wrong could you tell me?
Thank you to all of you
For SBCs like N2, there are dedicated images, so you don’t need to care on the DTB.
see https://github.com/CoreELEC/CoreELEC/releases
Just use CoreELEC-Amlogic-ng.arm-9.2.3-Odroid_N2.img.gz for first installation.
Ok i’ll do so
Thank you
