Hi
Can anyone tell me how to install such a dongle in coreelec?
I bought a cheap dongle like that, connected it to the box’s USB 3.0 and it doesn’t work.
I don’t know if it is related but I’m on CE 19.
Hi
CE needs drivers for that
For a start run this command and post url.
lsusb -vv | paste
I just tried two different USB to Ethernet dongles, and both were autodetected and worked.
One is a cheap Sitecom only 100M device and the second a Ugreen 1,000M device.
Minix device running latest nightly CE19.
Mine is faulty as it wasn’t detected in Windows either. New one is coming (supposedly tested) and I’ll test it tomorrow. From what you are saying it should work plug and play.
I bought the cheapest one on Amazon and it worked like a charm. It was a realtek chipset.
Ok, the new device came today but it is still not detected when plugged into the USB.
@vpeter
I tried running this command:
lsusb -vv
The result:
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 4.09
iManufacturer 3 Linux 4.9.113 xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 xhci-hcd.0.auto
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 31
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Hub Descriptor:
bLength 12
bDescriptorType 42
nNbrPorts 1
wHubCharacteristic 0x0009
Per-port power switching
Per-port overcurrent protection
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
bHubDecLat 0.0 micro seconds
wHubDelay 0 nano seconds
DeviceRemovable 0x00
Hub Port Status:
Port 1: 0000.02e0 5Gbps power Polling
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 15
bNumDeviceCaps 1
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x02
Latency Tolerance Messages (LTM) Supported
wSpeedsSupported 0x0008
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 3
Lowest fully-functional device speed is SuperSpeed (5Gbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0001
Self Powered
Bus 001 Device 006: ID 0480:a200 Toshiba America Inc
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0480 Toshiba America Inc
idProduct 0xa200
bcdDevice 0.00
iManufacturer 2 TOSHIBA
iProduct 3 External USB 3.0
iSerial 1 20141009000594C
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 20
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 20
bLength 5
bDescriptorType 15
wTotalLength 22
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000002
HIRD Link Power Management (LPM) Supported
bLength 10
bDescriptorType 16
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 2047 micro seconds
Device Status: 0x0000
(Bus Powered)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 4.09
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 2
TT think time 8 FS bits
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Port 2: 0000.0100 power
can't get device qualifier: Resource temporarily unavailable
Self Powered
I don’t see any USB device except Toshiba USB disk. No sign of ethernet adapter. Which one is it exactly?
This is the one:
RTL-8153B chipset
When I first plugged it to my windows 10 laptop it was detected in the network cards, then I wanted to try it on my coreelec box but to no avail. Then I wanted to connect it to my laptop once again and now I get a constant: USB device not recognized message. Is it a faulty piece once again?
Please unplug this adapter, reboot device, plug adapter and type this command. And post only url you get not the content itself.
dmesg | paste
I have this device, and it works fine in CE and on my PC.
Ok, I got mad and opened both devices. It turned out the first one got a loose VCC wire so I soldered it and the adapter worked instantly. My TV box now can use the max of my Internet bandwidth: on the box LAN I got 90mbits, now it’s 337
The second device has a slightly different PCB and it can’t be recognized.
All in all I’m happy.
Thank you all for help.
