I managed to acquire on of these really cheap but it’s only cheap if it works. It’s S905 I thought so it must load CoreElec. I was wrong. It will not boot from SD card. It seems that the aml autoscript doesn’t work because the box hangs on the Amlogic S905 logo when the sd card is inserted on boot.
The manufacturer does provide a zip file that changes it from android to XXXXElec kodi 17.3 but this is sadly lacking (none of the network improvements, no docker and it’s not leia).
Before I give up on this, can I just ask if anyone has any suggestions about getting it to run CoreElec? I don’t expect that there’s going to be anything but I’d be delighted if someone could come up with the answer. Thanks for reading.
I’ve tried the 2 gxbb-p200-1g-100M dtbs (with and without realtek wifi) to no avail. Also tried the dtb.img from the venz version of XXXXXElec and unsurprisingly that doesn’t work.
In checking the dtb names I noticed that the Android zip file for this box is p211-ota-20181214.zip. In your dtbs there are P200 P201 P212 etc but no P211.
I also have a Venz V10. Can you tell me which install method you used as described HERE
I tried the only one that seemed to match something I could do on the Venz (Recovery Method 2nd variant) , and used any random .zip file as instructed but I got an error on reboot so I’m not sure what to try next?
Thanks!
Chumbo
