Used the installtoemmc command. CE 20.0 is now on my eMMC however the contents of /storage/downloads that was on 19.3 is also on 20.0. Plus add-ons like OpenVFD that were on 19.3 and not on 20.0 on uSD are now on 20.0 on eMMC. Also I had Entware on 19.3 and not on 20.0 but /storage/.opt is on 20.0 on uSD.
I would have thought the eMMC would have been wiped before installing the contents of the uSD.
N2:~ # installtoemmc > log.txt
Type “yes” if you know what you are doing or anything else to exit: yes
1+0 records in
1+0 records out
512 bytes (512B) copied, 0.009400 seconds, 53.2KB/s
mkfs.vfat: /dev/mmcblk0p1 contains a mounted filesystem.
/dev/mmcblk0p2 is mounted; will not make a filesystem here!
N2:~ #
