please advise, you just run the script twice purely, or you use another way?
Be very careful using instructions for OLD CE Builds .
You may end up bricking your device with current CE images.
yes, more than 1 year ago, tried it to install to internal, result in broke the mxqpro 4k, lucky that i found out the way to revive it.
i just reading that someone successfully move it to internal, (and i lost my notes on how to unbrick the device if something happen), so better i ask for guidance from person who already success in doing it.
Mecool KI Pro running Coreelec -ng release 19.1 Matrix RC2.
I want to flash it from sd card to eMMC, in singlemode.
System is not supported: gxl_p230_k1_pro!
sad its not supported, so I tried with -x command.
ceemmc -x can find partition (eMMC size: 0x0003a3e00000 [16GB])
but cant flash singleboot because:
Install in single boot mode not possible!
No DT partition was found
is there a trick to solve the problem without doing dual boot mode?
Please try with latest nightly.
with newest nightly 20210424 its the same: No DT partition was found.
with nightly 20210423 same.
