Hello, I seem to have an issue with some channels that have a slight stutter. I believe I have narrowed them down to channels that run on 29.97 FPS.
My setup;
3 instances of kodi, only 1 with an AMLOGIC chipset (the one causing the problems)
- Minix with coreelec
Configuration
From what I have read, this is the preferred config;
- Adjust display refresh rate => On start / stop
- Sync playback to display => disabled
My tests
- I run the channel in VLC, it works well. the only difference I noticed between the channels that works and the ones that don’t is the FPS. 59 FPS runs smooth, 29 FPS stutters.
- I test the same channel with the other Kodi boxes and the channel works fine
Other information
I have also tried AMlogic script frequency switcher but that did not fix the problem
Logs with debug can be found here… actually, can’t upload logfiles and the xi.io fails to upload from coreelec
