Hi all
I have a minix u9 with 9.0.3 and Iptv simple client doesn’t load my channel list, it was working for me without any problem on 9.0.2. Any idea what goes wrong ?
Hi all
Without kodi log - no ideas…
log file
ix.io/1NWp
ix.io/1NWr
Enable “Wait for network” under CoreELEC network settings and report if there is any change.
dosent make change to enable wait for network.
Even if it’s started and I unable Iptv simple client it doesn’t load the list
Does your network works? Can you try to install (and then remove) one addon?
Also try to disable and then enable pvr iptvsimple addon. Does it load list in this case?
Yes network work fine, it try to install IPTV simple client with archive and same doesn’t load list.
When I disable and enable IPTV simple client it doesn’t load the list.
Then check your DNS settings because I saw
CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
I try with different configurations of my network but no luck, everything else work the weather is show and update, add-on update too.
I have same problem.
Local m3u list work without problem but remote path to list wont work.
How can I grab log for posting here?
I have s905 box with Coreelec on SD card.
I found this in log:
CCurlFile::Open failed with code 404 for http:/…
this is error for my iptv url
Your URL is wrong it seems.
This same url work on android iptv player without problem:
http://server.at:8080/get.php?username=xxxxx&password=xxxx&type=m3u_plus&output=ts
Then you have problem with DNS resolution because kodi(curl) can’t resolve your name server.at to IP address.
How can I fix that problem?
Check your DNS server in CoreELEC settings in Kodi.
Where can I find this?
In CoreElec settings I cannot finde nothing like DNS.
In system info I found this:
Primary DNS: 8.8.8.8
Secondary DNS: 8.8.4.4
Box IP is static
I can confirm that ping to server.at return ok data.
What to check next?
Enable kodi debug log and check that curl component is enabled. Then repeat the problem and post full kodi log file.
