Hello.
I am using CoreELEC-S912.arm-8.95.7-S912.img.gz on my Beelink GT1 Ultimate TV box.
I’ve configured IR codes following by instructions How to configure IR remote control . Codes were successfully loaded by ir-keytable -a /storage/.config/rc_maps.cfg -s rc0, but when kodi loaded with systemctl start eventlircd; systemctl start kodi, no button is working. After reboot it doesn’t work too.
Here is my map file:
0x40400d KEY_POWER
0x80f3 KEY_VOLUMEDOWN
0x80f4 KEY_VOLUMEUP
0x804d KEY_MUTE
0x8040 KEY_SETUP
0x8051 KEY_POWER2
0x8053 KEY_HOME
0x80bc KEY_MEDIA
0x800d KEY_OK
0x8026 KEY_UP
0x8028 KEY_DOWN
0x8027 KEY_RIGHT
0x8025 KEY_LEFT
0x801b KEY_BACK
0x8049 KEY_MENU
0x804e KEY_VOLUMEUP
0x8056 KEY_VOLUMEDOWN
0x8054 KEY_WWW
0x8052 BTN_MOUSE
0x8030 KEY_0
0x8031 KEY_1
0x8032 KEY_2
0x8033 KEY_3
0x8034 KEY_4
0x8035 KEY_5
0x8036 KEY_6
0x8037 KEY_7
0x8038 KEY_8
0x8039 KEY_9
0x8044 KEY_DELETE
Did you see the post with the pre made remote files?
Did you managed to do something to put your box remote controller to work?
I have a Mecool Kiii Pro, and have the same situation.
After installation of CoreELEC (official): 8.99.2 (S912.arm), works only TV remote controller…
The box remote controller works only when I start from shutdown.
