IR wakeup problem
I have an EVO - FORCE1 set - top box. I can use CE normally, and I can control it properly using the following RC - MAPS, including shutting it down. However, it cannot be turned on after being shut down. Is there any way to solve this problem?
Buckeye Broadband – StreamTV - Android TV Guide
dmesg below
login as: root
root@192.168.1.154's password:
CoreELEC (official): 21.1.1-Omega_nightly_20240913 (Amlogic-ng.arm)
      Machine model: Amlogic
     CoreELEC dt-id: sc2_s905x4_2g
      Linux version: 4.9.269 (docker@4e897066bdce) #1 Fri Sep 13 05:45:37 IDT 2024
      Kodi compiled: 2024-09-13 11:31:14 +0800
CoreELEC:~ # dmesg | paste
https://paste.coreelec.org/FloorBowling
CoreELEC:~ #
rc-maps below
# table mbh, type: NEC
0x22dc   KEY_POWER     #电源
0x22ca   KEY_UP        #向上
0x2299   KEY_LEFT      #向左
0x22c1   KEY_RIGHT     #向右
0x22d2   KEY_DOWN      #向下
0x2292   KEY_1
0x2293   KEY_2
0x22cc   KEY_3
0x228e   KEY_4
0x228f   KEY_5
0x22c8   KEY_6
0x228a   KEY_7
0x228d   KEY_8
0x22c4   KEY_9
0x2287   KEY_0
0x22f0   KEY_DOT         #M键/点号
0x22d0   KEY_BACKSPACE    #删除
0x2288   KEY_HOME        #主页
0x2282   KEY_CONTEXT_MENU #菜单
0x22ce   KEY_ENTER      #选中/确定
0x2295   KEY_ESC       #返回
0x228d   KEY_CONFIG   #设置
0x22da   KEY_STOP       #电视按键区的电源键
0x2281   KEY_VOLUMEDOWN #音量-
0x2280   KEY_VOLUMEUP   #音量+
0x229c   KEY_MUTE   #静音
0x2285   KEY_PLAYPAUSE    #播放停止电视按键区的TV/AV键
https://wiki.coreelec.org/coreelec:bl301
Thx for quick response.But s905x4 is not supported.
Device Serial number: 320b020b000000002dla91c92le05980
Using CPU type unknown (32): unknown
Using binary type because of CoreELEC DT-ID: Generic
Using /dev/bootloaderas bootloader partition
Did not find Amlogic inage header magic! Error-exit!
