Is it possibile to downgrade from CoreELEC 20.0-Nexus to CoreELEC 19.5-Matrix ?
I installed CoreELEC 20.0-Nexus ng version to Hk1 box(s905x3) but I it is not smooth. I want to downgrade to 19.5-Matrix. How can I make it ? Thanks
you can probably do it from CoreElec system options, specifically CoreElec settings:
Upgrade and select /manual/ update channel: CoreElec19.5 / available updates: CoreElec-Matrix … should download this version and install
Or just drop a tar of CE 19 in update folder through samba. Keep fingers crossed and maybe it will be ok. Better way should be a cold install from scratch.
coreelec:updates [CoreELEC Wiki] last paragraph warns about downgrading
But first check nightly build for CE20.
Thanks for you advice
OK,I’ll give it a try,Thank you!
Thans for your warning! I’ll wait for next version and see if resolve my problem.
You could try to restore a Kodi backup from CE 20 over a new fresh install of CE 19. See in the wiki about backup and restore settings. Not a smart thing but you should be able to draw a conclusion. Get a spare SD card and try.
