Is it possible to create a symlink in /usr/bin?
Hello:
I’s using rclone installed “manually” at:
/storage/.config/rclone
Using this version:
https://downloads.rclone.org/rclone-current-linux-arm64.zip
So, I have in the folder:
the files:
rclone
rclone.1
and
rclone.conf (with all my “remotes”)
I have used rclone during some years in this way, without any problem at all.
I “updated” rclone “manually” a lot of times changing old
rclone
rclone.1
binaries with new ones. The last ones are:
1.62.2 version
I have ~ 10 remotes configured, and I use the same “rclone.conf” with 4 different TV-boxes (S905X3, Amlogic-ng; CoreELEC 20.1).
Well… rclone 1.62.2 version DOES NOT WORK, and I had to return to 1.61.1 to get rclone working and mouting the virtual drives again.
It seems that there is a problem with “fusermount3”:
that is a file that new rclone 1.62.2 needs to mount the drives, and that seems that is NOT been used with CoreELEC.
I tried to install:
fuse3-utils
and now I have a:
/storage/.opt/bin/fusermount3
file, but it seems that is not enough for rclone 1.62.2, because rclone must search only in:
/usr/bin
So, I tried to symlink it in both ways:
ln -s /storage/.opt/bin/fusermount3 /bin/fusermount3
or
ln -s /usr/bin/fusermount /usr/bin/fusermount3
but…
“Read-only file system”, so I could NOT create the symlink for fusermount3.
So, finally, the questions:
1) Is there any way to “symlink” fusermount3 to /usr/bin?
2) Is possible to add fusermount3 to next CoreELEC versions?
Thanks in advance and kind regards
No and no.
Why not using rclone from entware?
If there is no alternative, I would do that.
Perhaps in next rclone versions a backward compatibility with “fusermount” is implemented… or not.
If not, I would follow the proverb: “If the mountain does not go to you, you have to go to the mountain” :rofl:
SOLVED!
Thanks to ncw ( https://github.com/rclone/rclone/issues/6844 )
I finally got it using CoreELEC:
  1. The latest version of rclone ( https://downloads.rclone.org/rclone-current-linux-arm64.zip ; at this moment, 1.62.2) “installed” (uncompressed binary) and with executable permissions:
    /storage/.config/rclone/rclone
  2. Installed fuse3-utils via entware:
    opkg install fuse3-utils
It goes to:
  1. Created rclone “services” like this:
[Unit]
Description=RClone Gdrive
After=network-online.target
[service]
Type=simple
Environment=PATH=/storage/.opt/bin:/.opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
ExecStartPre=/bin/mkdir -p /var/media/Gdrive
ExecStartPre=/bin/mkdir -p /storage/.config/rclone/logs
ExecStartPre=/bin/mkdir -p /storage/.config/rclone/cache
ExecStart=/storage/.config/rclone/rclone mount
--log-file /storage/.config/rclone/logs/rclonemount.log
--log-level INFO
--allow-other
--allow-non-empty
--tpslimit 10
--tpslimit-burst 10
--dir-cache-time=48h
--buffer-size=64M
--attr-timeout=1s
--vfs-read-chunk-size=64M
--vfs-read-chunk-size-limit=2G
--vfs-cache-max-age=5m
--vfs-cache-mode=writes
--cache-dir /storage/.config/rclone/cache
--config=/storage/.config/rclone/rclone.conf
Gdrive: /var/media/Gdrive
ExecStop=/bin/fusermount -uz /var/media/Gdrive
Restart=on-abort
[Install]
WantedBy=default.target
I needed to add:
/storage/.opt/bin:
in the PATH:
And it works perfectly!
