I just installed CoreELEC in my new N2+ but I don’t see the option to enable webservices. Is it possible to use the Kodi Android Remote? Thanks!
If you mean " Kore, Official Remote for Kodi app", it works perfect on CoreElec with appropriate settings, following this instructions.
Thanks, I tried that, but there is no option under Services, which now is under CoreELEC menu, to enable webservices.
Crazy. The Services menu was missing. I hadn’t restarted Kodi and when I did it appeared. Thanks.
