Good morning,
I am new to this, I have bought this equipment but I do not know if it is compatible, I can not find a dtb with the model. Can someone guide me?
Thanks and best regards!
Good morning,
Have you tried sm1_s905x3_4g.dtb?
I also have a X96MaxPlus (32.4). I used sm1_s905x3_4g_1gbit.dtb and it booted fine. Installing, using ceemmc, however did not work: “System is not supported”. I didn’t go try any further: don’t want to brick my device
If you read an ceemmc instruction fully then you will see a hint for unsupported devices in the end of it
Yep, but like I said, I didn’t want to risk it. I’ll just wait till someone else reports success with the X96Max+
Hi
i have the \ with 4GB ram, 32GB rom, 1Gb ethernet.
i have used the sm1_ac213_4g dtb , got working with a g30s remote and configured vfd.conf for getting time on display
i have not installed internally, only using coreelec on microsd
it’s a great device
EDIT
this is remote.conf
this is vfd.conf
BHH
The search facility is very useful.
Not the format we encourage.
Use the correct format or link to correct topic
No sellers links either
sorry Kostaman, i am not a seller (just the link to the product i bought) and don’t want to mess with rules!
i got all information using my google fu on this site
the OP will achive the same results with some time
thanks and sorry!
BHH
I took the plunge (well, not really a plunge after the post in the other thread that Compent pointed out) and installed CE on the emmc of my box. Works fine!
