i use coreelec 9.2.1 on wetek play 2. i have concerts on dvd .iso and when i send them running i have a lot of problems viewing the dvd menus and after a while everything freezes and I have to restart the wetek by removing the power. There is a solution?
can you test your dvd in a new nightly version ?
ISO playback under CE has problems. The dvd menu’s crash and you have to wait for about 30 seconds for it to dump and return to the CE menu.
You can get around it sometimes by pressing cntl-M to jump to the main menu if its crashing during trailers. And then immediately hitting enter to start the movie before that menu crashes.
As written use nightly version where ISO playback is fixed. Or wait for new stable version.
