I use wol on pretty much all my networked devices and only the N2+ does not work. I have switched cables / switch ethernet port.
Also tried sending wol-packet from router, phone and ipad.
The reds light is constantly on.
The networking lights both are on and blink when I send the wol-packet.
HI, did never us WOL, but I use the CEC settings. So if I power my TV on, N2 gets over HDMI Cable signal and boots up. If I turn TV out, N2 shuts down or go to suspend, what you prefer. This works also if I boot up TV and last source was Apple TV, N2 stays put and only if I switch to the HDMI where N2 is connected it boots up from suspend. Maybe this helps as long as you don’t find the WOL problem.
Greetings, J.
