Jerks when starting the film
Hello everyone,
I’ve encountered a bug for a few weeks ; when I play my films I have jerks, I have to go back a bit for the jerks to stop.
Vim4 - CE Kodi 21
https://paste.coreelec.org/RoughlyTelesave
07/23
22:05 launch of Captain Philips = jerky.
22:06 rewind = end of jerks
I would be very grateful if you could help me. :slight_smile:
Edit : I notice that moving the film forward or back a few seconds helps cancel out these jerks.
This issue has been there for a long, long time. Just do the jump back like the rest of us and that’s it. If it was easy (or possible) to fix, I bet it would already have been done.
@Boulder
I couldn’t find anywhere on the forum where this problem was discussed.
In your opinion, this problem, which has always existed on CE, is present on all hardware configurations?
It seems to come and go between systems, and the issue is discussed here and there I’m afraid. I’ve had it quite rarely on the S922X box but much more frequently on the S905X4 one.
There’s the nice “Unpause Jumpback” addon which helps with the case when jerkiness starts after pausing and resuming.
There’s sometimes also a/v sync issues after pausing and they are resolved by jumping back so there’s probably something in the Amlogic side that is causing it and making things hard or impossible to fix.
