No matter what I choose as layout in CoreELEC settings (fr, fr-latin1, fr-latin9, azerty) I am stuck with the qwerty layout. Also, if that makes a difference, I have set the keyboard to French azerty in the System => Appearance page as well. I do not remember it as being a problem in LibreELEC. Any pointers welcome. Thx.
Iâm upping this issue coz I had no reply. Surely I canât be the only French guy using CE⌠Anybody else having this problem? Apparently over at LE the devs seem to be aware of it as this would suggest. See posts 138 and 144. Not a major problem but a slight PITA when it comes to accents and punctuationâŚ
Last I checked, it is because CE and LE on ARM donât have Xorg, which allows the user to configure keyboard input. Thereâs no solution at this point.
So I take it Kszaqâs LE images used Xorg then? Because I remember having no problem at all with those. Too bad this regression in my opinion. Will have to wait I guess.
Tried it just now on wrxtasyâs build over at LE, to make sure I didnât wrongly remember it working. I can confirm the keyboard is correctly set for azerty in settings and in actuality. Without doing anything special. There you go, works in Krypton.
We need to keep in mind that CE is not LE (thatâs why they have different names). You need to decide which is your preference and understand that the two are not in competition.
True. I am not really complaining and on the whole quite pleased with CE, considering Leia is pretty much alpha even though Kodi is apparently not to blame here. Just wondering how and why azerty keyboards would just not be supported at this stage, moving from Krypton to Leia. And it seemed to me CE and LE did share more than a little DNA⌠enough to keep azerty users happy . But I guess the problem will be solved in due course. French speakers will have to bide their time until the problem is fixed. Thumbs up to the devs in the meantime.
I am using an external HW keyboard with German qwertz key mapping. I tried to switch kodi key mapping to qwertz and Coreelec - System keyboard mapping to de_latin1. Nevertheless the key mapping of the keyboard is stil US qwerty. How can I change it to support my German keyboard?
I would like to use normal german layout QWERTZ instead of the english QWERTY. In the last versions of CE it worked. Now i change it exactly the same way as before in 8.95.0 and now it does not work.
Do i understand it correctly that right now i need to be patient and this is a common problem right now?
Hi there, I got a USB keyboard with a German QWERTZ layout. Is there a way, to get that to work properly in coreelec? I tried several settings and still only get the standard us layout⌠What am I doing wrong?
Hi, as of CE 8.95.5 I no longer have a problem with my Rii mini i8 Wireless keyboard (AZERTY layout). Take a look in settings - coreelec and choose âazertyâ. To be clear, I use a Wireless keyboard not an IR one.
