Is there any way to control the Khadas Vim1 leds, they are controllable and not fixed-on but theres nothing exposed to turn them off or on.
Everything works except the leds, and I wont use black-tape because that doesnt look good. If its exposed in the device, it should be in the software aswell.
sysled {
compatible = “amlogic, sysled”;
dev_name = “sysled”;
led_gpio = <0x1a 0x09 0x00>;
led_active_low = <0x01>;
status = “disabled”;
