Hi All
I see there is a new version out. Will this one work as i am planning on getting one.
Hi All
Already working, but will be supported only in CE21 with kernel 5.15. No idea for NPU because we never use it.
CoreELEC (vpeter): 21.0-Omega_devel_vpeter (Amlogic-ne.aarch64)
Machine model: Khadas VIM4N
CoreELEC dt-id: t7c_a311d2_khadas_vim4nCoreELEC:~ # uname -a
Linux CoreELEC 5.15.78 #2 SMP PREEMPT Wed Jul 4 18:32:15 CEST 2023 aarch64 GNU/Linux
CoreELEC:~ #
Thanks @vpeter
So i should just buy the normal one then ?
Looks like I was wrong and VIM4N should also be supported with kernel 5.4.210.
I hope you don’t need audio passthru
You mean i cannot use Pass Thru settings for 5.1 Dolby in the settings ?
Right now this does not even work on my N2 +:)
Then you have something wrong in your settings. All is working. Only VIM4 and GT King II uses T7 A311D2 SoC what does not have DTS-HD & True HD passthrough. All others works fine up to 8 channels.
Thanks alot
I will go check.
So my Question still remains. VIM4 or the new VIM4-NPU version.
NPU means nothing to CoreELEC.
