i have the strange problem that my movies are buffered. the problem does not occur every time. maybe every third time i start the odroid. i have created a debug log here when it happens:
and here another one without buffering
does anyone here see the problem? i can’t explain it because it only occurs sporadically:/
Local network
I´m using KODI a long time on Windows or Mac or Raspberry etc.
I repeat, you don´t need to set any caching parameters if Your local network is working stable.
My N2 is running 24/7 and I watch video every day without any buffering.
High bitrate 4k HDR is playing fine using my local Gb network
i can also take the advanced setting out again and produce the error again. does it just not make sense for me if it only occurs sporadically? i have the problem even with smaller 1080p files and have a 100mb/s internet connection at home.
in the fritzbox i also see that the line is never overloaded.
i test the whole thing again without advanced setting and with a 1080p file. then upload the log again
so i took out the advanced setting and tried the same again with a 1080p file. first time no bufferin, restarted odroid and again the buffer problems are here again
Messing with the caching settings can cause its own unexpected issues. Best avoided and as has been said elsewhere a correctly functioning local network can stream content even at relatively low speeds. Local networks are complex beasts with many interactions which can upset traffic but are a nightmare to fault find.
