Hallo Coreelec Team,
i bought my Odroid n2 Coreelec Bundle in November.
From the Beginning i have problems with Kodi GUI restarting itself.
It only restarts when i start movies.
I tried all coreelec versions available.
I uploaded a log file at dropbox.
Shared with Dropbox
I hope somebody can help me.
Yours sincerely
Domenik
5 January 2020 15:36
#2
This is an automatic relaunch of Kodi after a system crash and is expected behaviour. Its probably a result of poorly packaged media files crashing the decoder.
Until November i used a intel Nuc with libreelec without these problems,
I played the same files.
5 January 2020 16:16
#4
The hardware decoders are different.
Does it effect all or just some of your files?
I solved the problem myself.
I edited the advancedsettings file to improve buffering. Deleting this setting solved my problem.
Domenik
5 January 2020 19:02
#6
Good to hear. Sounds like your decoder was giving up before the buffer had filled and reporting a failed stream.
Iām having the same issue, and also on an N2.
Are these the lines you removed from advancedsettings:
<cache>
<buffermode>1</buffermode>
<readfactor>20</readfactor>
<memorysize>139460608</memorysize>
</cache>
Nearly the same, i deleted all 3 lines
buffermode
readfactor
memorysize
the issue is gone
