2 days ago my CoreElec 9.0.2 stopped connecting to the internet.
The date/Time is stuck at 1 Jan 2015, and none of the addons work.
It’s connecting to my Wifi & showing ‘online’ but not to the internet.
At boot, I also get 2 popups
“URLLIB3 update Failed” and,
“kodi Six Update Failed”
The device is Nexbox S905
Here’s what I tried/observed. Note, I tried these steps one at a time, before trying the next step
I can access the Device folders from my Laptop over Wifi so its connected fine to my router. Kodi remote app also connects fine from my mobile.
Rebooted device and router a few times.
Changed from static (manual) ip address to dhcp and vice versa, but no effect.
I booted to eMMc (Android) and date/time is getting updated fine and internet works, in Android.
Back in Coreelec, I set the NTP server to pool.ntp.org (as suggested elsewhere).
I re-flashed Coreelec to the SD card, and set up Coreelec from scratch, setting region settings etc. But still no internet, date time stuck 1 Jan 2015 as before. (A brand new installation should work, right ?)
I connected to the hotspot on my mobile and at once the date/time updated and it got connected to the internet as normal.
This made me think my router had a problem. So I reset my router and setup the internet and Wifi settings from scratch in the router. But this had no effect-still no internet.
So now i have exhausted all methods to solve this issue.
Note: It was working fine. T his is something that happened 2 days ago.
I have uploaded the debug log here: Debug Log File
Can anyone help ?
