Kodi-Send missing module
With the latest 21.1 nightly 20241231 Kodi-Send no longer works, it returns the following error:-
**CoreELEC:****~** # kodi-send
Traceback (most recent call last):
File "/usr/bin/kodi-send", line 27, in <module>
from kodi.xbmcclient import *
ModuleNotFoundError: No module named 'kodi'
During handling of the above exception, another exception occurred:
File "/usr/bin/kodi-send", line 30, in <module>
from xbmcclient import *
ModuleNotFoundError: No module named 'xbmcclient'
Found this thread with the same error, but the solution no longer works.
It is this:
Sadly the issue was not fixed on Kodi Piers but now they introduce also to Omega.
Thanks :+1:
Export variable PYTHONPATH before using kodi-send:
export PYTHONPATH=/home/docker/build_dir/CoreELEC-21/build.CoreELEC-Amlogic-ne.aarch64-21/toolchain/aarch64-libreelec-linux-gnu/sysroot/usr/lib/python3.11/site-packages/kodi
Perfect thank you :+1:
To save typing this ever SSH session do the following:-
echo "export PYTHONPATH=/home/docker/build_dir/CoreELEC-21/build.CoreELEC-Amlogic-ne.aarch64-21/toolchain/aarch64-libreelec-linux-gnu/sysroot/usr/lib/python3.11/site-packages/kodi" > .profile
