I’m using amremote on an S905 box and the N2. The remotes are identical and both boxes are running the same remote.conf file. I’ve just noticed that the N2 does not “scroll” left, right, up or down when the keys are held. They do on the S905 box.
Both boxes are running the very latest nightlies.
I know there’s been a fair bit of forum activity about remotes on the N2 but can this be fixed without detriment to the people who had issues with “phantom” repeats?
I checked now the amremote setup and my remote buttons are getting repeated normaly on the N2. May you have something in the kodi config what is blocking a repeat of these keys?
Sorry @Portisch but I can’t think of anything that I’ve set that could be responsible. I tried the meson-ir method to remind myself how bad it could be but that wouldn’t repeat with the remote either. So now i’m back to amremote.
I will do a clean install on another sd card and see what happens.
So, I updated an earlier SD card version and did a hard reset. Added just enough to allow me to connect to a hard disc connected to my S905 box downstairs. Used my wireless USB keyboard to add the remote.conf, stored on the hard disc into the .config file. Rebooted and the remote works BUT DOES NOT REPEAT.
I think we’re both baffled. For my part, I can live with this because my keyboard does scroll. It would be nice to know why though wouldn’t it?
This is the remote.conf Iremote.conf (620 Bytes)
'm using
Decided to move my TX7 to CoreELEC SD Card install today.
Stock Vanilla install CE 9.O.1. Android still installed to Emmc
I used my modified remote.conf that was used with LE by copying it to .config folder
Rebooted. Nothing changed.
The remote works but not as amremote. None of the modifications work either.
Picture of what my keys on my modified remote.conf do.
Edit Update: I just fired up my TX3 Mini S905w with CE 9.0.1 SD Card Installed.
Android still installed to Emmc This box has the identical remote as the TX7
I used the SAME Modified remote.conf which i copied to .config folder of the Tx3 Mini
Rebooted . It works on this box. TX3 Mini Working Aml Moded remoteLog Compare
TX3 Mini Snippet of working remote log Difference.
CoreELEC (official): 9.0.1 (Amlogic.arm)
CoreELEC:~ # ls -l /flash
total 162992
**drwxr-xr-x 4 root root 8192 Jan 29 10:57 Android**
drwxr-xr-x 2 root root 8192 Jan 28 18:48 LOST.DIR
-rwxr-xr-x 1 root root 156528640 Feb 27 19:22 SYSTEM
-rwxr-xr-x 1 root root 48 Jan 3 03:52 SYSTEM.md5
-rwxr-xr-x 1 root root 795 Feb 27 01:50 aml_autoscript
**-rwxr-xr-x 1 root root 4482 Jan 3 03:52 config.ini**
drwxr-xr-x 2 root root 8192 Feb 27 09:22 device_trees
-rwxr-xr-x 1 root root 41165 May 10 13:04 dtb.img
-rwxr-xr-x 1 root root 10260480 Feb 27 09:22 kernel.img
-rwxr-xr-x 1 root root 48 Jan 3 03:52 kernel.img.md5
TX7 Non working Snippet Missing drwxr-xr-x 4 root root 8192 Jan 29 10:57 Android
and -rwxr-xr-x 1 root root 4482 Jan 3 03:52 config.ini
1. CoreELEC:~ # fdtget -t s /flash/dtb.img /meson-remote/ status
2. Error at '/meson-remote/': FDT_ERR_BADMAGIC
total 163264
drwxr-xr-x 2 root root 8192 Jan 1 2015 LOST.DIR
-rwxr-xr-x 1 root root 156528640 Feb 27 00:51 SYSTEM
-rwxr-xr-x 1 root root 48 Feb 27 00:51 SYSTEM.md5
-rwxr-xr-x 1 root root 795 Feb 27 00:51 aml_autoscript
drwxr-xr-x 2 root root 8192 Feb 27 00:51 device_trees
-rwxr-xr-x 1 root root 344064 Feb 27 00:51 dtb.img
-rwxr-xr-x 1 root root 10260480 Feb 27 00:51 kernel.img
-rwxr-xr-x 1 root root 48 Feb 27 00:51 kernel.img.md5
Pleased to say @Portisch that I now have repeating. I only tried the first and smaller file and it is working well.
I’m guessing that there’s something left over from kszak or wrxtasy in the Coreelec I’m using on the S905 box that makes repeat work with my original file. The file was obtained from kszak’s LibreElec thread for s805 boxes and had been working with everything until now.
Damn Right. @Pelican
First time I’ve used the CE Download Helper to burn an image using Etcher.
I always in the past used the correct dtb.img after i burn the image.
Not paying attention to something i never used before. Got me.
All good now. PrivateBin
Yep you’re spot on @Portisch. With the latest remote.conf (640 Bytes) I still have repeat on the N2.
I think you’ve cracked it. Now wait for the stream of people who are still using these remotes. Come to think of it, everyone I know thinks I’m a nerd so it could be a very small stream!
For my part, I’m so glad to be part of this because I learn so much from what emerges from these discussions. By following the CoreElec and LibreElec forums, I’ve learnt rudimentary use of SSH, what advanced settings and autostart can do and have migrated from the disaster that is Microsoft to Ubuntu on my laptop. I even understand some of it!
Is amremote restricted to the NEC protocol? I tried it just for curiosity, It reacts to the NEC protocol, but for RC-5 protocol for example no remote: message shown…
It feels a bit quicker response than meson-ir, so it great to have both on CE, but if its restricted to NEC its a pitty. Most of my remotes are rc-5/6, + custom raw codes, co thanks god for meson-ir
