Hi all, having an issue where i get some strange slowdown in videos for about 5-10 seconds then it will resume fine? This only happens once or twice in a 1h.30m film
This is playing directly from a HDD.
Never seen this in the stable before, has anyone else experienced this?
I did have a problem with DTS sound cutting in and out, after a FW update on my TV it now works fine, but as i come to think about it i think it started when i enabled passthrough.
Im not sure but at certain points in sort of just goes into a locking up and catching up kinda thing, ill try to get a vid of it, but ill do the cleanup first.
Hiya, I am using an N2 Latest nightly, Movie is using AC3 8 bit 48hz
I am connecting to my soundbar by toslink from the tv.
I am using multi channel sound and passthrough.
Ok i was watching Birdbox, which i watch alot because i love it…
It just happened at the point where they let gary in and hes on the floor talking, so i rewind to take a small video clip and it then plays fine. So appears its not at certain points rather than something causing it, hope this helps.
Just started watching the walking dead season 10, its happened 2 or 3 times in the first 3 episodes. Never ever had this before, used to be as smooth as butter, turned of passthrough and still the same so its not that.
I managed to video it but had to do it quickly, its 150mb, hope this helps.
The problem is that when the video changes from one scene to another, past one of the chapter markers, it starts dropping frames terribly. If I restart playback from a point AFTER that chapter marker, it plays fine.
In the log files, I believe that the problem starts around the line: ‘2020-03-11 20:10:48.783 T:3227091840 DEBUG: CPtsTracker: pattern lost on diff -803092911.000000, number of losses 2’
Before that point, the ttd values are ~ +270ms. After that point, the ttd values are now ~ -802836ms, a very strange value.
