Le Potato -ng build?
Hi folks,
I’ve just seen the update for CoreElec, and I’d like to say once again many thanks for the continous support!
Looking at the release notes, I’d be quite curious to try out the -ng version, but I cannot find a download for -ng and Le Potato. Is there any, or should I try the generic one with the correct device tree? Or is that discouraged?
Thanks for advice!
Hauke
NG= Next Generation SoC like S905X2, S905X3 and S922x
That means no NG for Le Potato, it´s running an older SoC
You have to use non-NG image
OK, stupid me…
Thanks for clarification!
You can check this topic but keep in mind that they’re funhouse builds!
