I cannot seem to get LEDs working on Homatics R 4K Box using CoreElec. I have tried all the different versions of the Homatics LED Addon (Knight Rider Kit), but I cannot get them to work in any way. I have tried giving permission via SSH, use an autostart.sh script, etc. Is there something I am missing? I am using the generic image for Amlogic devices with 4GB and 1GB.
Maybe you need the right DTB ?
Don’t know if it helps, but you should use the sc2xxxx_sei_280 file … Don’t know if it named correctly but something like this.
I just did a fresh install and used sc2_s905x4_4g_1gbit as DTB (the generic one), as usual. I had no Idea sei_280 was for Homatics. Will use that one this afternoon and probably fix the issue. Thanks.
