I don’t know if this issue is already spoked, i will try. I have a s905x with a 1TB nas on lan . When i try to clean the video library on the nas , this operation is very very low. This might do 30 minutes and sometime the process may block. The nas, switch and router have 1Gbps link but the s905x 100Mbit. I know that this may decrease the speed of the link but especially lately it has become more slower. In fact before it was slow but the work ended but now it is even slower and sometimes it does not finish cleaning. Any suggestion? Thanks
You can find PR for this issue here:
So it’s WIP from kodi side…
I have a lot of content and it cleans in just over a couple of minutes. I find one of the big differences is the speed of cleaning is the sd speed a box installed to internal is generally quicker. My old kodi media box used to take 5 mins with a conventional HDD when I swapped to mSata it droped to less than a Min.
Hello, i see that the issue still remain. Any chances to solve? Thank you!
What’s your setup? I have a S905X connected to a 4TB NAS over a USB 1Gb (so about 300Mb in practice!) and it cleans the library pretty quickly.
I assume you go to the settings; Media;Library: Clean library.
I have over 1200 movies on a nas & it doesn’t take very long on my H96 Pro S912 or android kodi on my shield, I use homeplugs.
I assume that you have updated the library, & all movies ave been scrapped?
Perhaps, you could try scrapping them all again using a different scrapper.
There is an addon called missing movies, which tells you which movies haven’t been scrapped to the library.
One thing I have find is it is better to have smaller amounts of files in each directory. I find if I have a lot of films in one directory the cleaning process will often clean off films that are still available.
