Hi all, since the update to 9.2 I think (certainly the last major update), my ae1000 disconnects at random times. I had this problem when I first installed CE but somehow managed to overcome it. I can’t remember how though :(. I haven’t changed any router settings, it is set up to use DHCP with a manual assignment at the router. I have the faintest memory of possibly blacklisting a module, but I might be confusing that with mucking about with Arch on a laptop. Checking my history in SSH gave me no joy (it was virtually empty), so I feel it must have been something I did within the kodi UI. Any ideas ?
Thanks.
I have seen that the Linksys AE1000 USB WiFi adapter is a device that only works on the 2.4GHz bands. This is possibly your problem, the 2.4GHz frequency has a long range but it is usually subject to interference of all kinds and the lack of availability of free channels.
Thanks cubi. It definitley works on the 5Ghz band too. I can connect, and it will be fine for between 20 minutes up to some hours. I had it working for months with no issues (after I did whatever I did to get it stable) back on the update before 9.2. But since that update it has gone back to intermittant connection again.
