I would like to install CoreELEC 19.2-Matrix_rc3 on the device
MINIX NEO U22-XJ. I have a Logitech Harmony 650 remote control. Will the remote control in CoreELEC work properly or should it be set up?
Thank You!
Thank You!
I have collated my notes on the best set up of a Harmony 650 with Coreelec / Kodi
I would expect just about all of that to apply to your hardware, although it’s possible the device specific stuff might need tweaking (wakeup, repeat rules in udev etc).
Kudos on your effort
