Since you can program the Harmony remote to emulate any other IR remote, whatever you can do with your original remote will also work with it - simply “learn” the Power ON command from your original. ![]()
Working Perfectly on my H96 Max X2 (S905X2)
Just had to tell Harmony no power buttons
No long press on OK for menu BUT Menu button does the same
I set one up for a friend. Found Beelink in Logitech. It came up when entered.
I ended up leaving it on all the time since it draws so little power.
