- what box would you recommend that fits my requirements (see the list below)?
- the Vero 4K+ was fine in the past, but OSMC is not stable any more and I want to move back to CE or LE. Would the Vero4K+ work with CE and which image to use?
Use case
home cinema
AVR with 7.1 speaker system
4K 3D projector
General Media-Center-specific requirements:
IR or BT Remote control, also for power on/off
CEC for fallback
silent
low power
missing something important?
General Performance requirements for media center:
1 Gbps ethernet and AC wifi access: library database and content are served from remote via NFS, SMB, MySQL, PLEX
fast local storage (SSD): metadata and fanart are stored locally
smooth handling of content for
1080p24, 1080p60, 2160p24, 2160p60, with 3D, with 10-12 Bit color space (HDR10, opt. Dolby Vision)
7.1
HD audio supporting FLAC 24 bit, 192 kHz
content decoding of H.264, H.265, MPEG4, MPEG2, preferrably in hardware
HDMI audio passthrough: PCM, Dolby Digital, Dolby TrueHD, Dolby Atmos, DTS, DTS-HD, DTS-HD MA, DTS:X
opt. hardware deinterlacing
Automatic Resolution & framerate switching (to match the video file)
Specific Kodi-Platform requirements:
IR Receiver,
opt. Bluetooth 4.2 or higher (ext. USB device is ok)
Power on/off via IR and/or BT
HDMI 2.0b, optional 2.1, CEC
Ethernet 1 Gbit
opt. Wifi5 AC or WIfi6 (ext. USB device is ok)
USB 3.2:
2x A-Connector,
opt: additional 2x C-Connector
SSD built-in (250GB or more) or free mount bay for SSD
opt. passive cooling (no fan)
silent
opt. low power consumption of platform
GPU: 10 bit HEVC (Mesa 17.1 or higher, Kaby Lake or newer)
HDR10 capable
opt. SDR capable
