Looking for users with no working WiFi or BT
Would you be willing to test one more image and post some logs? Update, disable/enable bt in kodi and post logs. Remove USB dongle before reboot.
https://drive.google.com/file/d/1VDB0GMUZey6_peqOtUUNwhKD7iig1LQl/view?usp=sharing
paste /storage/.kodi/temp/kodi.log
dmesg | paste
journalctl -l | paste
bluetoothctl list | paste
bluetoothctl show | paste
Tried the image (without the dongle), didn’t work again…
The strange thing on my box is that I have to install Matrix 19.1-rc1 first in order to make the wifi work. Then I can update it to rc4. If I install rc4 first, there’s no wifi. But with rc1 (and rc4) the BT-Dongle gets detected on kodi and can be used. That didn’t work on my first setup (CoreElec 9.2.7.)… Don’t know if this information is helpful… However, here are the results:
CoreELEC (vpeter): 19.1-Matrix_rc_vpeter (Amlogic-ng.arm)
CoreELEC:~ # paste /storage/.kodi/temp/kodi.log
http://ix.io/3lsL
CoreELEC:~ # dmesg | paste
http://ix.io/3lsM
CoreELEC:~ # journalctl -l | paste
http://ix.io/3lsN
CoreELEC:~ # bluetoothctl list | paste
CoreELEC:~ # bluetoothctl show | paste
http://ix.io/3lqk
Hi!
I recently got my tv box, and it is a X96air 2GB+16GB+2.4G Wi-Fi. The Wifi chip is 8189FT,V I have verified it and it works perfectly fine.
My question is what it would take to get the wifi chip to work with newer kernel versions or for e.g. other Linux distros?
What i can see is that in a recent release 19.1-Matrix_rc2 RTL8188FTV-aml driver was added.
In the dtb I can see this config: compatible = “amlogic, aml_wifi”;
The aml_wifi seem kinda generic how does that refer to the correct driver?
I guess what i would need to make this work is:
  • Add a driver like the one mentioned above.
  • Create a proper dtb to select the driver.
correct me if im wrong.
Thank you for the good work!
Good day! Box Rasse-001 (s905x). Wi-fi does not work. Bluetooth works.
CoreELEC:~ # udevadm info /sys/bus/sdio/devices/* | paste
http://ix.io/3lW8
Should be supported with next CE-19 nightly tomorrow, thank you for report.
Thank you very much, I’m really looking forward to it!
Wi-Fi didn’t work. The item wireless connections is missing in the settings.
CoreELEC (official): 19.1-Matrix_nightly_20210507 (Amlogic-ng.arm)
http://ix.io/3m2W
dmesg | paste
dmesg | paste
“Sorry you cannot post a link to that host.”
h**p://ix.io/3m3c
thank you, I make a new test image. will take a bit…
@serg255 please try with this update:
https://mega.nz/file/mSxSxCBQ#qx43EBXvjGp6z3RLSuYJZ0VzVmIy-8QXAbRue6I8OUE
Please post a dmesg | paste again after update. Thank you.
Thank you! How to write “tar” to sd card? Rufus doesn’t understand.
Place the tar in update folder.
Or by SSH:
cd .update
megadl https://mega.nz/file/mSxSxCBQ#qx43EBXvjGp6z3RLSuYJZ0VzVmIy-8QXAbRue6I8OUE
sync
reboot
Wi-fi didn’t work. But the item wireless networks appeared. Bluetooth work.
dmesg | paste
h**p://ix.io/3m3V
@serg255 you need to make a dmesg log from Android where wifi is working.
Also a dtb dump is needed. This dump can be done in CE by SSH:
dd if=/dev/dtb | gzip > /storage/downloads/dtb.img.gz
Then share the dtb.img.gz with us.
https://mega.nz/file/kdB22ZTC#SoPpyMxYyvo3AzAbgK2CtrOM8PK0xJaI4liD7z1Lrfk
https://mega.nz/file/9YZgiTqT#O2dcSidAphSK6JB0mloqFjvRHf8tuUeDbA1t4JVqelQ
Thank you for the logs. Android use another driver for this chip. Maybe it’s not possible to include it. Will need to check it in more detail.
Hi, My device Beelink GT King Pro.Wi-Fi didn’t work. wireless connections do not appear.
http://ix.io/3m7U
If you’re using latest nightly there’s a problem with wifi revert to the 6 of may one or wait for the next one.
