Read first post, if you don’t provide what is requested, no help.
After connecting a network cable to provide you with the needed information, WiFi networks started to show up in the coreelec settings! Great success!
I will test to see if it stays that way when I restart the box without a network cable. Would you like me to run any test commands?
Perhaps I was too far away from the access point. Everything appears to be fine now. Thank you for the great work devs!!!
Coreelec is love!!
So is the 7668 chip just SOL for bluetooth without help from Mediatek?
Pretty much unfortunately.
Isn’t this the driver for Bluetooth?
That is for USB not SDIO.
This one here is apparently SDIO
Have a Bluetooth USB dongle (ID 0a12:0001 Cambridge Silicon Radio) that’s shows as “No Bluetooth adapter found” on the CoreELEC interface. Using 9.2.2 build on Odroid N2. Did the lsusb on the device, but not sure which info to pull out.
http://ix.io/2jj7
@jacoghi It’s been reported before, I haven’t been able to implement the driver for MT7668 yet, I may be able to if someone is willing to enable remote login to their device for me to try a few things.
As mentioned in this post (RTL8814AU chipset support) I have an Aukey AC1750 wifi dongle (RTL8814AU chipset), worked on ODROID-C2, does not work on ODROID-N2 with latest nightly (Apr 23). Output of lsmod|paste from the (working) C2 is here: http://ix.io/2jrb
Output of lsusb from the (non-working N2) is:
Bus 002 Device 004: ID 1058:25a1 Western Digital Technologies, Inc. Elements / My Passport (WD20NMVW)
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc.
Bus 001 Device 004: ID 0bda:8813 Realtek Semiconductor Corp. RTL8814AU 802.11a/b/g/n/ac Wireless Adapter
Bus 001 Device 003: ID 20a0:0001 Clay Logic
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
This is a link to the device on Amazon: https://www.amazon.co.uk/AUKEY-WF-R12-AC1750-Wireless-Adapter-Function-3-0-Port-black/dp/B01LSABXX8
Cheers
Dhry
Mini m8s, s905 box. Working wifi but no bluetooth.
http://ix.io/2jOE
It is an old box but just pulled it from a drawer and installed CoreElec.
I too have a mini m8s s905 and tried the last night 23042020 and BT not working (rtl8723)
Yes i can also confirm BT is not working in the nightly for the mini m8s.
I have a theoretical question. If we get the bluetooth driver for mtk7668 to work will we need to upgrade to a nightly build or can we stay on the current stable build and just install the new driver?
Is that even possible or does the os need to be recompiled?
What about the dtb file?
@pedr0 @Vermillion or anyone else with a device with either RTL8723BS or MT7668 with BT not working… if you are able to setup remote access (port 22 TCP) then I can look into the issues further, I don’t have physical access to a device with either chip so I’m limited in what I can do.
@greatCornholio the dtb is unrelated, the OS needs to be rebuilt.
If possable i would rather run the commands and post the outputs.
You are welcome to access my A95X Max (MT7668) but apart from using local SSH with port 22 i don’t know what else you will need to be setup to enable remote connectivity.
