Hey
In 9.2.7 usb was working, after upgrading to matrix_rc4 usb dead. Booted back to 9.2.7 and usb is fine again.
Here is dmesg: http://ix.io/3mvz
Hey
Maybe same thing like this usb issues?
Possibly. I will upload my android dtb like you where told, perhaps that will help solve it.
Edit: I too came from ATVXperience, don’t know if that means anything, but I know I didn’t have a dtb partition before that.
Android dtb
dtb.img.gz (47.2 KB)
Problem solved, I used the autostart script you where given and it worked.
Edit: So the coreelec dtb is an overlay ontop of this android dtb? It’s a bit confusing, because I didn’t have a dtb partition before I installed atvxperience. i wonder how it worked before then, pre-matrix…
Remember to double reboot after each update, after the first reboot the usb will still be dead.
