I have some older Versions of this s912 Player (Mecool M8S+ Pro L 3/32).
I use the q201…3…dtb.img. All other images lead to a error on the USB-Controller, so I cant control the player at least with my mini-keyboard.
Unfortunally I cant even detect the key-codes manually, since I have following error message:
CorePlayer:~ # ir-keytable -t
No devices found
Any clue whats wrong?
Is a brand new player with fresh installation of latest coreelec Image
Found that hint on other threats and tested some of them and edited to first text above. It still isnt working.
It is not the usual remote, it is a voice controlled too. But anyway you are right, the receiver seems not to work.
I have the Mecool M8S Pro L 3GB/32GB. I was mistakenly under the impression that the LAN on this box was 1GB. So I used the gxm_q200_2g (I think) the same one I used on my H96 Pro
I only tried Coreelec on this for a short while but it seemed to work ok. I used the Mecool KIII Pro remote, profile on my Logitech 350.
I mainly want to use Android, & the supplied remote didn’t have a mouse, which makes using some apps difficult. So I bought this
Which has wireless remote, so it should work on Coreelec
yes. something similar I have too, but I want to be able to use the original remote.
With q200 files, USB is not working (and remote either)
With _2 files only 2gb of rams are used, isnt`t it?!
WIth my previus M8S pro L (same player), the remote worked perfectly after downloading the remote.conf from android and safe it on the correct destination inside coreelec
I have the same box with the same remote. For me only IR (from the remote) works with this box (under Kodi). Very annoying. Right now i am using a Xiaomi Bluetooth remote, but every time i reboot the box, i need to manually “Trust and Connect” the remote again.
I would only need a simple remote, like the Xiaomi remote but without the struggle connecting the remote to Kodi.
