Magicsee N5 Max X4
Good night.
I have a Magicsee N5 Max X4 with Coreelec Nexus in eMMc. The system works perfect
although with some things that do not work.
The first thing is the status led. when is off is blue and when it is
lit is red. It should be the opposite.
I would also like to know if there is any vfd file to view the display
of the device and thus have control of the time and temperature of the device.
Thank you
happens to the device is the status led… it should be inverted and they light up well. blue on and red off
Search the forum:
It is already “0” so it might need to be “1”:
#!/bin/bash
GPIO=`fdtget -t x /flash/dtb.img /gpioleds/sys_led gpios`
GPIO_ACTIVE_FLAG=`echo $GPIO| awk 'END {print $NF}'`
if [[ "$GPIO_ACTIVE_FLAG" == "1" ]]; then
  echo "SYSTEM LED GPIO IS CORRECT"
  exit 0
else
  echo "Changing System Led GPIO_ACTIVE flag"
  GP=`echo $GPIO | sed '$s/\w*$//'`
  GPIO=$GP"1"
  mount -o remount,rw /flash
  fdtput -t x /flash/dtb.img /gpioleds/sys_led gpios $GPIO
  sync
  mount -o remount,ro /flash
fi
Do you have the specific device, the n5 max x4 ???
is that sndo looking for the vfd file too
Script should work on any/most boxes…
For VFD have more search guides/how to.
How to config VFD…wiki
Since you have CoreELEC on internal may have some work to do.
Data/info from Android may be needed.
Maybe will have to remove CoreELEC from internal
Flash Android back for pin out…
Guide will explain all in detail
Well, we are fixed because there is no trace of android left… and getting the firmware for this is not easy.
I’ll wait for someone to believe it and share it.
Thank you anyway for the information.
Okay
Can always go to CoreELEC Wiki
Recovery n Upgrade
With ceemmc tool can make a copy of internal to SD/USB Drive.
Then would boot from external and free up internal.
Then could flash Android when available.
With S905X4 there is no dual Boot
So best to have CoreELEC on external
Of course iz alot of work
If Happy on Internal
All Good
Happy Testing
