MATRIX for x96max 905x2 4/64 is it possible?
I have X96MAX 4/64 905x2 with kodi 18.9 and 9.2.8. Can I install matrix? What rom would it be? Here at CoreELEC I only find stable matrix for X96MAX 2G RAM. What about the 4G gigabit version in Matrix, is it not supported?
Why you just not try g12a_s905x2_4g_1gbit.dtb and report back if it works?
Then we can add it to the downloader database.
g12a_s905x2_4g.dtb and g12a_s905x2_4g_1gbit.dtb rom: Amlogic-ng.arm-19.3-Matrix-Generic.img.gz
I have tried it with a pendrive with these 2 DTBs without success.
This is a file system defect of your µSD. Wait the 2min, maybe it get repaired.
The truth is that I did not wait the 2 minutes. Today I will try again. By the way I try with a pendrive not with microSD.
Indeed after 2 minutes the box restarts and the matrix starts. However it seems that ethernet does not work even though it assigns me IP. I can’t go into the coreelec addon to try to select wifi either. This with the g12a_s905x2_4g_1gbit.dtb
