I have noticed in Matrix, memory usage will grow over time. While I never noticed Kodi using anything more than 800MB in a ‘normal’ household 24/7 scenario on some Chinese makes in the past, just checking now Kodi is using 1587MB running for 10 days.
It’s not really an issue since the odroids carry 4GB and i am not bothered by it filling up, but i was just curious what others experience. I have read a rather detailed discussion on GitHub somewhere about this but I can’t seem to find it anymore.
Well, actually…i have started using a couple of (paid) streaming services that I had not been using before quite heavily ;). Was just thinking of slimming some down to more resemble the old setup to start with…
No, when I have time. But I did some binging on Hbo Go for a few hours and nothing heavy memory involved. Actually, if you use 1.5 GB of memory from 4GB (Odroid C4) that’s fine. Also its fine if you use same memory from a Chinese box. If your system handles this without hiccups, don’t bother. Sit down, watch and relax!
Look… What’s the idea of having tens of thousand of RAM on a device and we are using just …10% only?
Why are we wasting money on hw if we don’t using it at full capacity / full force? Only to avoid FOMO?
No idea. I know it’s not an issue. In fact, I’d say go at it as long as it’s there. Just wondering what changed, because it could be running for months on end and still be at 700MB. So I just removed all but discovery plus on one C4 and left it running…
Try to get some logs, maybe some devs will look on and enlighten us about the source of evil. Get some logs with all the services enabled and other logs with less services on background, to compare.
