Mce remote works with k1pro but it didnt work. No support some remotes but How activated this mce remote
I don’t understand what you mean. Have you read
If you are using a device with one of the above IR remotes you can re-enable support by executing
the corresponding command below via SSH and rebooting.
echo "meson-ir * a95x" > /storage/.config/rc_maps.cfg
echo "meson-ir * mecool" > /storage/.config/rc_maps.cfg
echo "meson-ir * minix_neo" > /storage/.config/rc_maps.cfg
My English very bad
I use mecool remote but I want to use my mce remote. I updated coreelec and dont work with mce remote. I need to activated mce remote
etc/rc_maps.cfg
rc-rc6-mce rc6_mce -
rc-rc6-mce libreelec_multi
table for Xbox DVD Playback Kit
rc-xbox-dvd xbox_dvd.
multi-table for amlogic devices
meson-ir * libreelec_multi
I’m sorry I can’t help you
rc_maps.cfg should be copied to /storage/.config
MCE remotes are supported out of the box.
Therefore you should remove any entries from your rc_maps.cfg.
Your rc_maps is wrong. As relkai said remove it and reboot. MCE works ootb with meson ir
