Does anyone know if it’s possible to get serial access to a Mecool KIII Pro?
I don’t want to take mine apart if there’s nothing to connect to…
It’s important to leave the 3.3V disconnected. Only connect TX\RX\GND.
Looks like some soldering is involved…
no need 3.3 v connect
Here’s how to take it apart:-
I can’t figure out how you would connect to the contact points since they are not pins but very shallow holes, more like dimples, in which you can’t insert a dupont connector.
Hehe, here is how NOT to take it apart
Good job I watched it first
