I have problem with install to internal command (using “installtointernal”). For my box i choosed dtb “gxl_p281_2g”, but the console shows me:
CoreELEC (official): 8.95.4.3 (S905.arm)
CoreELEC:~ # installtointernal
One of BOOT, SYTEM, DATA or DTB partitions is missing.
Make sure that you are using a correct device tree and a device with internal memory!
My box has 2gb RAM and 16GB Rom.
On libreelec I found this post, but Iam not sure what does it mean (is it missing in device tree?):
S905X: You can leave a tree that is already present on SD card (fresh install only) or choose one according to your RAM amount.
If internal memory of your box is not visible when trying to install to internal memory (i.e. /dev/system does not exist): - try a device tree with _nand suffix
- if that doesn’t help, try a device tree with _slowemmc suffix
Thank you for help,
Edit: I found this topic (Mecool M8S Plus W - installtointernal not working), so I think it is not possible?
