roden
24 April 2022 15:34
1
Right just spent 6 hours getting my shares to work in win 11 on CE,
and somehow broken my TVH server, it just says starting and sticks at 0%, i am sure i had this once before but cant remember a thing about it, other than it was like having your teeth pulled to install and configure.
where do i start.
24 April 2022 15:45
2
Can you roll back to a backup ?
roden
24 April 2022 15:48
3
Just found one so going to try now, although its 4gb not sure why
24 April 2022 15:51
4
It probably has all the thumbnails backed up, you can disable that in settings in future.
I would backup your broken system just in case the restored backup is still broken and then you can go back to where you are now.
roden
24 April 2022 15:59
5
yes have one from a few days back and one from today, restoring now see what happens
roden
24 April 2022 16:06
6
Right backup has worked. phew!, 3gb of the data is debug txt files, need to find how to turn this off.
A simple cron job could delete this files.
If You change any config, maybe some other things will stop working
roden
24 April 2022 16:27
8
only thing i could see in tvh was a tick next to syslog in debugging, turned that off and see what happenes.
system
Closed
24 July 2022 22:27
9
