Hi guys,
My U22-XJ doesn’t boot from the USB stick directly connected in a USB port when I have my USB HUB connected in another port (with another USB Stick, external keyboard and airmouse BT dongle)
Is there any way to controll the boot sequence?
Current workaround which is kind of anoying is to disconnect the HUB boot then reconnect the HUB. Once booted all devices on the hub are working as they should.
