CoreELEC 19.4-Matrix_rc1 and addon Speedtest. Box connected via LAN.
When I check the internet speed, the upload speed is very different from the download and is significantly lower, although in Android is very similar. My internet line speed is 300 Mbps. Android shows about 260-280 Mbps downloads and about 180-230 uploads. In CoreELEC downloads is about 160-200 Mbps and uploadas just about 30 Mbps. At first I thought it was because CoreELEC was working from an SD card, but after installing it to the internal memory, the result remained the same.
I’m not sure if I’m writing on the right topic.
If you need a log, I’ll give it in the evening.
vpeter
13 January 2022 12:16
2
You need to test speed locally to get real numbers. This is from my box
minix_u22xj_max: # iperf -s
Server listening on 5201
Accepted connection from 192.168.0.4, port 52180
[ 5] local 192.168.0.7 port 5201 connected to 192.168.0.4 port 52182
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 107 MBytes 895 Mbits/sec 0 362 KBytes
[ 5] 1.00-2.00 sec 113 MBytes 946 Mbits/sec 0 378 KBytes
[ 5] 2.00-3.00 sec 111 MBytes 935 Mbits/sec 0 395 KBytes
[ 5] 3.00-4.00 sec 112 MBytes 941 Mbits/sec 0 436 KBytes
[ 5] 4.00-5.00 sec 112 MBytes 939 Mbits/sec 0 436 KBytes
[ 5] 5.00-6.00 sec 112 MBytes 942 Mbits/sec 0 436 KBytes
[ 5] 6.00-7.00 sec 112 MBytes 944 Mbits/sec 0 436 KBytes
[ 5] 7.00-8.00 sec 112 MBytes 941 Mbits/sec 0 436 KBytes
[ 5] 8.00-9.00 sec 112 MBytes 941 Mbits/sec 0 436 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 942 Mbits/sec 0 436 KBytes
[ 5] 10.00-10.04 sec 4.72 MBytes 951 Mbits/sec 0 436 KBytes
[ 5] 0.00-10.04 sec 1.10 GBytes 937 Mbits/sec 0 sender
Accepted connection from 192.168.0.4, port 52184
[ 5] local 192.168.0.7 port 5201 connected to 192.168.0.4 port 52186
[ 5] 0.00-1.00 sec 104 MBytes 874 Mbits/sec
[ 5] 1.00-2.00 sec 108 MBytes 909 Mbits/sec
[ 5] 2.00-3.00 sec 109 MBytes 913 Mbits/sec
[ 5] 3.00-4.00 sec 109 MBytes 913 Mbits/sec
[ 5] 4.00-5.00 sec 108 MBytes 910 Mbits/sec
[ 5] 5.00-6.00 sec 108 MBytes 904 Mbits/sec
[ 5] 6.00-7.00 sec 108 MBytes 903 Mbits/sec
[ 5] 7.00-8.00 sec 108 MBytes 903 Mbits/sec
[ 5] 8.00-9.00 sec 108 MBytes 902 Mbits/sec
[ 5] 9.00-10.00 sec 108 MBytes 906 Mbits/sec
[ 5] 10.00-10.04 sec 4.60 MBytes 897 Mbits/sec
[ 5] 0.00-10.04 sec 1.06 GBytes 904 Mbits/sec receiver
Thank you @vpeter . I see that everything is great.
Svetaine:~ # iperf -c 192.168.88.224
Connecting to host 192.168.88.224, port 5201
[ 5] local 192.168.88.219 port 53446 connected to 192.168.88.224 port 5201
[ 5] 0.00-1.00 sec 114 MBytes 953 Mbits/sec 0 361 KBytes
[ 5] 1.00-2.00 sec 113 MBytes 946 Mbits/sec 0 414 KBytes
[ 5] 2.00-3.00 sec 112 MBytes 943 Mbits/sec 0 414 KBytes
[ 5] 3.00-4.00 sec 112 MBytes 941 Mbits/sec 0 458 KBytes
[ 5] 4.00-5.00 sec 111 MBytes 935 Mbits/sec 0 508 KBytes
[ 5] 5.00-6.00 sec 112 MBytes 941 Mbits/sec 0 508 KBytes
[ 5] 6.00-7.00 sec 110 MBytes 924 Mbits/sec 0 532 KBytes
[ 5] 7.00-8.00 sec 113 MBytes 944 Mbits/sec 0 532 KBytes
[ 5] 8.00-9.00 sec 113 MBytes 946 Mbits/sec 0 658 KBytes
[ 5] 9.00-10.00 sec 111 MBytes 933 Mbits/sec 0 689 KBytes
[ 5] 0.00-10.00 sec 1.09 GBytes 941 Mbits/sec 0 sender
[ 5] 0.00-10.04 sec 1.09 GBytes 935 Mbits/sec receiver
system
Closed
14 April 2022 22:10
4
