Don’t use 4096, that is not a native resolution for TVs.
Our recommendation is to keep GUI at 1080P, but you can use 3840x2160 if you really want to.
But don’t use 4096x2160, it will not look right.
Are there still any issues that may occur after installing to internal storage using CEEMMC?
Someone wrote that he had lost the Ethernet port, someone wrote that after switching off the green LED lights up or the HDR problem. I would like to use dual boot using CEMMC. Minix is listed as supported.
How long does it take you to boot coreelec from EMMC on this device. Thank you
I have 2 of these running with no issues. Boot time is about 20-25 sec but I run them 24/7. I can’t speak on dual boot since I erased android.
Hi.Everyone
My Minix U22-XJ MAX. HDMI Sound Ethernet WIFI does’t work.
Thank you.
Support is on the way. But wifi should work according to our information.
Support of the Minix U22-XJ Max was added by 12.12.2021. So use the new g12b_s922x_minix_u22xj_max.dtb for this device.
If the display looks “greenish” you need to disable Dolby Vision in Android settings (settings → minix settings → display → screen resolution) as CoreELEC does not support Dolby Vision.
how can activate the minix remote control? I use the internal IR connector with my logitech harmony elite. Thanks for your help.
One topic is enough
