Hi All
Just got a Minix U22X-J MAX and installed CoreELEC Nightly as wanted DV support.
Now I noticed Kodi seems a little washed out apart from playing movies which is fine and i noticed that the box is outputting 4:4:4 and i know movies are normally in 4:2:2 so wondered if that why kodi is washed out as it been displayed in 4:4:4 but has been designed at a lower 4:2:2 so washing out the blacks. the videos seem to play ok though.
so the question is should i leave the box in 4:4:4 or change it to 4:2:2 becasue i noticed that my pc plays movies and displays kodi correctly as it does not wash out the blacks ?
what is the correct chroma subsampling when playing movies and TV shows only in SDR, 1080p, 4k and 4K HDR/DV
the only way to change it is to boot into android and change it there and then boot kodi i suspect.
Also, about Dolby vision i have a 1080p tv and going to upgrade it soon to 4k and when i installed coreELEC i placed the Dovi.ko in the root folder where the img installer is and installed kodi coreELEC but there is no option for Dolby vision is that becasue i have the tv res set to 1080p but when i get a new tv and set it to 2160p it will appear?
thanks all
