Minix are releasing a new box, which you can pre-order
https://www.minix.com.hk/products/u8k-ultra
Seems a bit expensive to me, but thought some people might be interested
Yes, it’s very expensive compared to others.
If you buy cheap, you buy twice
did you actually see the price of this box?
$349.00 !!! USD!!!
you can get the ugoos sk1 for like $200 with same CPU/GPU
no NPU but you basically paying $149 for an NPU on this. CRAZY!
You’re statement says, you should buy a $50k car than a $10k car because the $10k is cheap and you’ll have to buy twice…
$349 for just a player.
Never said this.
There are a lot of cheap devices with unsupported chips, missing drivers, slow emmc etc. etc.
Dont´t compare a media player against a car
SK1 and am8 have NPU
well you did say that. you wasn’t talking in general terms. you referred to anything that wasn’t in this price range “cheap”, did you not?
EVERYTHING compared to this is “cheap”.
are you saying the SK1 at $210 is cheap?
£350 my jaw jst hit the floor twice,I thought it was a typo at first but there serious,the ugoos has the exact same hardware at £220,that will bomb for sure,what are they thìnkin
For that price I can get a AppleTV and am6b+.
